Latest Revit updates for batch print, DB link and another failed
Hi I just received 3 latest updates for batch print, DB link and another thing that was suppose to fix some unsigned signature issue but this coudlnt install. It showed the following error messages
see attached
tuuletin
Try to reinstall these add-ins.
For me it seems, that your local security policies block the installation of new dll-files. Contact you system administrator or be sure, you are logged as an administrator before add-in installation. Cat Frustrated
I think it didn't work as I updated while running Revit. Uninstalled and reinstalled - works now.
hall_jarodd
I am having trouble with these updates as well. But my error is that another version of the product is installed. And for the life of me I can't figure out where it is hiding. I have uninstalled per the windows uninstaller and that didn't help.
Download ccleaner. Once you've uninstalled via windows uninstall, then run ccleaner and do the registry cleaner. Then reinstall those updates. worked for me.
