L steel profile
4 ANTWORTEN 4
Nachricht 1 von 5
l.yong1
1419 Aufrufe, 4 Antworten
L steel profile
Hi there,
Does anyone know where can I find L-shaped steel profile inside revit?
Thank you. Have a great day:lächelndes_Gesicht_mit_Sonnenbrille:
Please see attached photo.
4 ANTWORTEN 4
Nachricht 2 von 5
lucdoucet_msdl
als Antwort auf: l.yong1
There are multiple options in Revit depending on the use of the word "profile". Here are there relative directory locations in the Revit family libraries.
  1. There are detail elements for structural steel angles as the "L" shaped profiles. They can be found in the "Detail Items | Div 05-Structural Steel | 05120"
  2. There are 3d structural steel elements. They can be found in the "Structural Framing | Steel | M_L-Angle.rfa" ;
  3. There are 2d Revit profile families. They can be found in "Profiles | Framing | M_L-Angle-Profile.rfa"
You just need to go to the Insert tab and select the load the family type you need.
Hope this helps,
-luc
Nachricht 3 von 5
l.yong1
als Antwort auf: lucdoucet_msdl
Good morning Luc,
Thank you for your advice.
I will give it a go this evening.
Nachricht 4 von 5
kadmonkee
C:\ProgramData\Autodesk\RVT 2020\Libraries\US Imperial\Profiles\Framing\Steel
depending on which system you are using Imperial or Metric this is based on Windows file structure
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Nachricht 5 von 5
l.yong1
als Antwort auf: kadmonkee
Thank you. I will let you know how it goes. Have a great day:lächelndes_Gesicht_mit_Sonnenbrille:
