Keynote file path missing and keynote legends removed when upgraded.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a 2016 revit project that's on BIM 360. Many models, Many Links.
The Keynote file is stored on a local server. When I go to the keynote settings, the file path is blank.
When I pick the reload button, it reloads the database and the file path then appears.
When I save the File, close it and open it again, the path is blank.
We're trying to upgrade this model.
When I publish the latest, download the model and open it detach, save it to a new location and try to reset the keynote settings, the setting dialog box opens and the path is blank. I pick on the reload button, the keynotes reload and the last saved path appears. I save the file local and close. When I open/create a new local, open the keynote settings the path is again blank. Pick on the reload, file reloads and the path appears. I should note that during this process while in 2016, all of the keynotes still stay populated and the keynote legend appear as expected.
When try to upgrade the model to 2017 or 2018, the all of the keynotes are blank, the keynote legends are no longer in the model. When I go to setting and try to reload the keynote file, it reloads it, but none of the tags fill out.
So far it's only one of the models that we found the issue it.
Anyone else ever run into this issue?
Thanks in advance.
