Keynote File issue
Keynote File issue
DavidF7CBA
Keynote File issue
DavidF7CBA
Previously used to keynote elements by internal type keynote.
Tried to use Keynote file instead but ended up having trouble (No time to resolve).
Need to revert to old method, but can't eliminate the connection from the keynote file!  Purge & Audit didn't help.
Can Any one help please.
RDAOU
@DavidF7CBA
If the keynotes are already predefined in the Element's type properties (ie: the 30/30 shown in image 1 of your post), the Tag for Element Keynote should display the parameter displayed therein...regardless of the file specified in the Keynote Location Path
If the Keynotes are not defined in the Element's type properties, you will need to specify the Keynote file to use under Keynotes settings...ie: you need to browse and locate your previous file
DavidF7CBA
Thank you for the answer.
I keep getting "?" instead of the Type Keynote:  ie. 30/30 in my first picture.
Although Keynote.txt file is not found by the file : ie see my second picture.
Is there any fixing process  I need to run to get this problem resolved?
As mentioned, the Keynote Tag has not changed,
I decided to introduce the Keynote.txt. file and that caused the "problem"
RDAOU
@DavidF7CBA
Make sure you are using the correct Tag Type... it should be the one which is Labeled Number (NOT Test)
Select the Tag and check the properties palette Type selector/drop down
DavidF7CBA
To make sure I inserted a new one from the instalasion library.
No luck.
RDAOU
@DavidF7CBA
can you tag an element >>> copy to clipboard both element and tag then paste in a new project
Upload here
DavidF7CBA
Will Try, Thanks for the effort.
