Keyboard Shortcuts for a Sub-level Command
Seychellian
Seychellian
I am in the process of converting a lot of AutoCAD details to Revit linework and I am finding it laborious to have to take multiple steps to execute a command. For example I have a shortcut setup for Detail Line (DL) but Revit will seemingly always default to the 'straight line' option and I have to select any alternative linetype I want to use from the ribbon (with my mouse). This becomes really laborious and time consuming when you are doing a lot of linework. For example if you are doing a line with a variety of straight and curved sections you have to go back and forth with the mouse to the ribbon and change the selection for each section of the line.
I keep thinking that I am missing something.
Does anyone know if there is a way to use keyboard shortcuts more effectively so as to avoid this situation?
For example is there a way to assign a keyboard shortcut to a second or third level command i.e "Detail Line > Spline" or "Dimension > Angular > Center of Core?
Thanks!
_Vijay
I think unfortunately u need select the line individually if need to change the line type..
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Seychellian
Thanks for your response. This sure makes drafting laborious in Revit. As someone who has never detailed in Revit before can it really compete with autocad at detailing? I have a feeling that I will end up exporting the Master drawings out to CAD and completing them in there.
