hello,
I have been trying to see if I could get a Room Tag that would keep the leader alignment always orthogonal to the view when switching between types.
This would save a significant amount of time for the jobs in which the already placed tags need to be swapped so to show different room info. Whether it be for when the tags used for a particular view need to be changed or for when the views have been duplicated to start off a new drawing series and reusing the already placed tags.
While doing it, I have noticed that the leader reacts to the different types of contents of the tag family but was unable to understand it's underlying working so to ensure how the different bits of text need to be aligned.
Does anyone know the rules by which the tag leaders react to the different Tags' families' contents?
See video attached showing the behaviour as well as the Revit Family being used.
Thank you
Solved by RobDraw. Go to Solution.
It's been a while since I've played around with this so my memory might be outdated if things have changed.
The end at the tag targets the center of the objects. You might get what you want by centering everything. I've used invisible lines to control the target point with good results.
hi @RobDraw ,
Thank you for your reply.
I tried that but it there is always some nudging to the leader while switching between types.
I am aware that I am being pedantic but I was also curious to what extent could this be set to work flawlessly.
I gave you two options. Using invisible lines might give you more predictable results than just trying to align the centers of the objects.
I tried using an invisible line spanning through the max height for all tag types but it produced the same result quality as without it.
I do not want to add horizontal invisible lines because I would rather the leader extending all the way to meet the label text for each particular type.
