Joining two extrusions
adam.machala
adam.machala
How would I go about joining the two coping stone extrusions?
cbcarch
What happens when you extend both of them to intersect each other? Extend past each other then use a void to Cut Geometry?
You could make a Family as a cap to fill in the space as another option.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
RDAOU
@adam.machala
You should use a Sweep instead of an Extrusion. (Use 3D to pick edge as a path ... model a generic profile in a family and load it)
Alternatively, you can use a Roof Fascia
