Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
joining floors and walls priority
hey fellow reviteers i have a problem
i want to be able to conrol the way my floors cut my "foundation layer"
the way i want it to cut is the concrete slab cuts the leca and insulation layer but the insulation layer of my floor does not cut into the foundation layer
martijn_pater
You can change your floor assembly -> edit floor type -> edit assembly and change priority under function (structure [1] / substrate [2] / thermal air [3] etc. Editing this there should resolve your issue probably.
 Suggested bedtime reading:  "About Applying a Function to a Layer of a Compound Structure".  It's a page-turner!
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
yes it should it just doesent matter what i set the layers to i could set it as finnish but would still cut trough structure
It should. Post your file.
