joining floors and walls priority
hey fellow reviteers i have a problem
i want to be able to conrol the way my floors cut my "foundation layer"
the way i want it to cut is the concrete slab cuts the leca and insulation layer but the insulation layer of my floor does not cut into the foundation layer
martijn_pater
You can change your floor assembly -> edit floor type -> edit assembly and change priority under function (structure [1] / substrate [2] / thermal air [3] etc. Editing this there should resolve your issue probably.
 Suggested bedtime reading:  "About Applying a Function to a Layer of a Compound Structure".  It's a page-turner!
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
yes it should it just doesent matter what i set the layers to i could set it as finnish but would still cut trough structure
It should. Post your file.
