Joining Curtain Panels on Obtuse Angle
Kev_D
Message 1 of 9
Kev_D
As the title suggests, can we join the Curtain Panels on a weird angle. and have a line showing the Mullions joined.
Plan Views of the CW
Original.
Proposed.
Red lines showing Panels joined (cleaned up) and the line in the Mullions. I am thinking it would just have to be Detail Lines and Filled Regions, but I try to avoid them at all costs.
Replies (8)
Message 2 of 9
Change the panels to a basic wall type of the same thickness and material.
Message 3 of 9
I don't understand what I'm looking at in your screenshots.
I am familiar with "obtuse" though.  Shawshank Redemption.
Message 4 of 9
Kev_D
That could be a result. Will have to wait till tomorrow to try. I'm sure it will still tag as a panel. Yes/no?
Cheers
Message 5 of 9
Kev_D
One of my favourite films. Maybe cause I am Irish.
Anyway the screenshots are from a plan. Showing a CW without a Million at the intersection. I want the glass to be frameless.
Message 6 of 9
Ah! Plan View! You even said "Plan View" in your post. Guess I need to read gooder.  😉
Irish! I get it, Red. Good one.
Message 7 of 9
So I'm envisioning a condition like this, where the mullions are omitted at the corners.  So, if you don't want to replace the panels with basic walls, how about a "bead" mullion. That is, a small L corner mullion the same thickness and material as the glazing.  Cleanup in Plan View could be done using the Linework tool with Invisible Lines -- if it matters.
...or, model a custom-shaped Panel for those conditions.
Message 8 of 9
Kev_D
Worked a charm. Thank you
Message 9 of 9
Kev_D
Thanks @barthbradley  but the Wall suggestion worked.
