Importing Bentley Raceway and Cable Management .dgn files to Autodesk Revit
We are working on Bentley Raceway and Cable Management and saving the files in .dgn format but once we are importing the file in Autodesk Revit parametric data associated with 3d Geometry
is not visible?
Is there a question in there?
Try in this order:
- Saving down to an older DGN version before link it in Revit
- Export to IFC and link it in Revit
- Export to DWG and link it in revit.
hmunsell
When bringing DGN into Revit i usually have the best results by saving the DGN to a DWG. Then you can linking the DWG into Revit.  In this case, after exporting to DWG, open the DWG and run EXPORTTOAUTOCAD. this will remove any proxie graphics and make it all basic Autocad elements.
Howard Munsell
