Joined geometry in family not joined in project
bartlomiej_janik
bartlomiej_janik
I made a joined geometry but after nest in project, it is not join anymore.
I had tried "share/not shared", "cut when loaded" etc.
Please advice, thanks.
nozci
When I assign a material (it is by category right now) in the project, I can join them in the project. Maybe there is a more practical way I don't know. Somehow it should be an issue, related with material I think.
 It's not monolithic. It's an assembly of separate and distinct components (e.g. shared families).
You could make the cut pattern solid and the same color as the projection linework if you want to make it "appear" monolithic.
You could get there by creating and merging Parts together.
handjonathan
Hi @bartlomiej_janik
Thanks a lot for posting your question to the forums!   Has the solution suggested by @nozci @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
bartlomiej_janik
The suggested solutions are helpful, but they miss the point. I'm afraid my question wasn't precise. I would like to modify the family so that when loaded into the project it is alerady joined correctly, without additional modifications. Is it possible?
