Join or merge Hollow core slab (part assembly) with wall element
shihas.pms24
Message 1 of 8
shihas.pms24
Hi friends,
How can i join or merge  hollow core slab (Parts assembly) with wall.
Join geometry its not activate. or any other solution instead of join.
Replies (7)
Message 2 of 8
narsimhamurthy21
can you share the revit file of this praticular to understand how you created this.
Message 3 of 8
shihas.pms24
wall is default family and hollow core slab is part assembly. Done by precast tool in revit 2024.
Message 4 of 8
Don't go into Edit Assembly Mode. Go to a regular Model View and use Join Geometry just as you normally do, by picking the two elements directly.
Message 5 of 8
Either join the source components of parts outside of the assembly view, or edit parts, turn on parts grips and stretch it.  To join components, set the view to show original.  To modify parts, set the view (model view, not assembly view) to show parts and use TAB to select parts.
Message 6 of 8
shihas.pms24
Actually, join geometry cannot select while try to pick part assembly that's why i rise this question.
Message 7 of 8
I gave you the proper instructions above.  Read it again.  In a regular Model View (NOT an Assy View), press Join Geometry first and then select Wall and Floor.
Message 8 of 8
