Join Mullions in Curtain Wall
vitaliy0001
Message 1 of 14
vitaliy0001
I have a simple vertical curtain wall.  Mullions are the only structural members.
I also have a horizontal Curtain System for skylights coming into the top of this curtain wall - the mullions of both systems are all aligned.  The mullions are in the form of an upside down 'L'.
Where they intersect at 90 degrees, I want to join the mullions to not have ugly lines in section views.  However the join tool doesn't recognise the mullions at all - I can't select them to join them when it is active.
What is the correct procedure to accomplish what I want?
Replies (13)
Message 2 of 14
Message 3 of 14
RDAOU
@vitaliy0001
In case using the system L Corner does not work for the situation Wall/Skylight which you have...You will need to do the following:
  1. create a Custom Mullion
    • first create a profile using the Profile - Mullion template
    • Load into the project
    • In project browser scroll to Curtain Mullion
    • Right click "Rectangular Mullion" and create a new type - Custom L Corner
    • Right click the new type and Go to Type Properties
    • Replace the Profile with the one you created in 1.a and Apply
  2. the replace the top horizontal  border of the wall  & remove the border of the skylight as shown in below GIF
Message 4 of 14
You could create the L mullions using:
- structural framing (image)
- in-place sweeps
- adaptive family
Message 5 of 14
Is this what we're talking about?
Curtain Wall Systems.
Message 6 of 14
vitaliy0001
This is exactly what I wanted to achieve. Is there any other semi-automated way of doing this in curtain wall settings?
Message 7 of 14
vitaliy0001
So are you suggesting curtain systems for both vertical and horizontal surfaces will result in joined mullions?
Message 8 of 14
Try model them as a sloped glazing by extrusion, or a curtain system by face, instead of a vertical curtain wall and a horizontal sloped glazing.
Message 9 of 14
Yes. Easy, breezy too.  No fuss. No muss.
Create a Curtain System from a Mass | Revit Products | Autodesk Knowledge Network
Message 10 of 14
vitaliy0001
Thanks.  This worked for joining the mullion joins.
Now, I have another question - how can I make the top glass panel extend across over the vertical panel, instead of having a gap as per the screenshot?image.png
Message 11 of 14
Do you mean like this?
One approach would be to use an L Corner Mullion as I mentioned at the beginning of this thread.
***Note "Thickness", "Leg 1" and "Leg 2" and "Material" values in L Corner Mullion Type Properties.
Message 12 of 14
vitaliy0001
Not really the effect I wanted - the glass should simply overlap without any mullions there.
The only way I can see is to unlock the panel and manually edit each one which takes hours, but has the required result. This is really difficult, because as soon as you make it manually, it dissociates from the plane and you have to re-position it.
Message 13 of 14
RDAOU
@vitaliy0001
Curtain walls and curtain systems sometimes require a little bit of extra effort in order to get the desired outcome. The join between panels is easy and doesn't need to be as tedious as you described but it also depends on how you model the system/element...
If I would be using a curtain system, I would use a custom panel at the join between the vertical wall and the roof which would give the below result (see GIF)
Message 14 of 14
vitaliy0001
Thank you very much. This is a great solution. Much appreciated.
