Join/cut walls question
Hello!
So, I've been trying to join a certain type of floor (with rectangular holes in it) with a wall on which it sits. But since one hole is right on top of a wall, I don't get the required shape of the wall (it has these spikes). Any good suggestion on how to get rid of these spikes without deleted the hole in the floor? I am still kinda new to Revit so please help.
Check attached picture.
Thank you!
Domen
You can give the wall a top offset (negative). Or you can attach the top of the wall to a reference plane and adjust the height of that.
That would lower my entire wall. I just need to get rid of these spikes (check new picture).
Edit profile. Or split the wall into two and lower one half.
