Item duplicates when using rotate command
perez_121465
Observer
perez_121465
Observer
Observer
Hi, so I'm having this problem that's basically when I try to use rotate command on an object revit doesn't let me complete the action because it duplicates the object. How could I fix this?
perez_121465
Observer
Observer
Thank you so much, this has really helped me.
Untick Copy from option bar when rotate.
