05:51 PM
I have a sort of general question about item codes, something that is rather elusive to me;
I have inherited a set of windows and window tags. The tag reads from the "tem code" field and comes up blank when I tag the window. I have tried to find where this item code is located and cannot find it. I know I can change it to read from keynote or type mark but I just want to know where this item code parameter is reading from. I asked google but no specific answer. Is the item code some sort of coding code and not available to edit? In that case, why would the window tag be reading from that parameter instead of Type mark or similar.
Cheers!
