How to create Custom Parameters for Materials in Revit?
jrfrost
Message 1 of 16
jrfrost
Is there a way to create a custom parameter for a material? I'd like to add parameters such as "Provided By", "Phase Used", etc. that will show up in my finish schedule. I've tried adding a field to the parameter schedule, but I can't get it to let me type anything in.
Replies (15)
Message 2 of 16
Edit:  By the way, these parameters are added to the elements, not the materials themselves.  So if you have multiple materials for one elements then this does not work.  You would have to go fro some other approach, such as Create parts + Parts material schedule and add the parameters to that schedule.
The only way for you to add these parameters directly to the materials is using the existing fields as shown below.
Add the parameters to a material take off schedule.
Message 3 of 16
jrfrost
I've tried this many times and it's not basing these parameters off of an actual material. It instead is basing them off elements in the model that have the that material applied to it. Because of this, any material that's applied to an element with multiple materials applied to them is linked to those materials as well. The video attached shows what I mean. Please let me know if I'm missing something.
Message 4 of 16
No you are not missing anything.  See the edited first part of my reply above.
Message 5 of 16
jrfrost
Too bad. So I basically have the "Description, Comments, URL, and Keynote" parameters to jury rig this, since "Keywords" and Class" or not a schedulable parameter. Seems like Revit materials and it's library are outdated and are ready for an upgrade.
Message 6 of 16
Viveka_CD
Hi @jrfrost
We hear you!
If you looking for a feature to get implemented, I suggest you post your idea at the Ideas-page on the Revit ideas board
Message 7 of 16
breakingbad
It might be a bit late for you now but you can create custom material parameters.
Create a new project instance parameter, type "Text" and select the material category from the categories list.
 Open the materials browser and select the material you want to edit. In the bottom left corner of the browser click the "custom parameters" button and edit your parameter values. You can then add it to any schedules etc.
If you want to be able to tag with this parameter then create it as a shared parameter.mat browser.png
Hope this helps.
Message 8 of 16
FAIR59
seems to me you can simply add a project parameter for the category Materials.
Message 9 of 16
clausneergaard
Which version of Revit are you using? I don't see this option that you've posted a picture of, anywhere? I am looking at this same issue, and I've found nowhere, that it is possible to add any shared parameters or anything to specific materials?
This would be nice, though, to be able to add custom parameters to materials, in general ...
Thanks.
Message 10 of 16
breakingbad
You just create a new parameter in the usual way (Manage>Project parameters>Add...) and tick "materials" in the category list for it.
Once you've created a materials parameter the "Custom parameters..." button will appear on the materials browser to allow you to set the values in your materials.
It works in all versions of Revit.
Hope that helps.
Message 11 of 16
martijn_pater
You can add project instance parameters here under material category.
Message 12 of 16
clausneergaard
Nice one! Didn't see that small icon in the lower left corner.
Thanks!
Message 13 of 16
i want to see the parameter in identity tab under product information...is it possible.??
Message 14 of 16
martijn_pater
Don't think so, you can add parameters to materials but what you're asking about is changing the user interface. But perhaps you could do it if you create an add-in for it...
Message 15 of 16
i want to add a parameter name KPN Number so it will be easy for our production team to take particular material representing KPN Number. Suggest me if this is any way to do. Thank you
Message 16 of 16
kpatel2QWBH
Thanks, This really helped me.
