Copy/Monitor without Copy?
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
1060 Aufrufe, 6 Antworten
I made an architectural model then copied this file and stripped it for all but structural elements, for a structural model. Now can I set up monitoring between these models without actually doing copy, since the elements are already there? What are the correct steps to do this?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
It doesn't work that way. The elements between the two files have zero relationship unless you copy them using copy/monitor.
Nachricht 3 von 7
als Antwort auf: ToanDN
So what are my options for making linked models from this outset..?
Nachricht 4 von 7
Why did you split one model into two in the first place?
Nachricht 5 von 7
I have requirements to have separate structural and architectural models (separate Revit files). And the structural shall be linked into the architectural model. I wasn't aware exactly what that linking technically entailed, so I started out with the architectural model and completed it. Now I have two finished models. One being mostly a stripped copy of the other, with minor modifications and different views and drawings.
Nachricht 6 von 7
MichaelWarwick7522
Go to Copy/Monitor and select Monitor, lets you pair elements up.
Nachricht 7 von 7
Here is how I would do given you already made two files:
- Open Architectural file, create a Link_Structural workset
- Link Structural file in as Overlay, origin to origin, change it to the workset above
- Go over the model and delete Architectural elements overlapping Structural elements
- Go back to Structural file and do the first two steps (with different workset naming of course)
- Most of the time that is all you need.  Update one model will reflect on the other when you reload the link
- You can choose to Monitor the link but IMHO it's unnecessary.
- Some people choose to copy/monitor element from one model to another.  I would only copy/monitor Levels and Grids, not actual building elements.
