IT IS REALLY SIMPLE...
vincent.tiburcio
Message 1 of 8
vincent.tiburcio
Community Visitor
Community Visitor
Why doesn't Revit let you save a backup local before it completely crashes?... I just lost 2 hrs of work
Replies (7)
Message 2 of 8
It would if it could.
Meanwhile, set Save Reminder Interval and DO NOT ignore when it pops up asking you to save.
Message 3 of 8
RobDraw
Saving often IS simple.
Rob
Message 4 of 8
HVAC-Novice
Not having an autosave feature, that saves in the background while you still can work in the project, is one of the most missing features.
You can vote on a request to make this possible.
Until they provide that feature, manual saving after the reminder is all you can do.
Revit Version: R2026.4.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Message 5 of 8
mhiserZFHXS
While I don't disagree that auto-save should probably be a feature, why in the world would you go 2 hours without saving? Even in programs that auto-save, I manually save at least every 30 minutes. Hopefully this is a hard lesson learned.
Message 6 of 8
HVAC-Novice
I also sometimes find myself manually saving in Word or Excel, even if it autosaves. So I understand your paranoia 🙂
But in Word/Excel the saving only takes as long as the click takes. Revit takes a few seconds during which you can't use Revit. This is annoying and I see how that prevents someone from saving "too often". I realize this is based on file size and network speed etc.
That is why I would hope an Auto-Save in Revit would work in the background while one still can use Revit. Basically, unnoticeable instead of pausing Revit every 15 minutes for a few looooong seconds.
I think OP learned their lesson the hard way. Sometimes that is the best way to remember the lesson....
Message 7 of 8
mhiserZFHXS
It'd be nice if that were implemented for all saving, not just the proposed auto-save feature!
Message 8 of 8
HVAC-Novice
Goes without saying.  I would hope if they can figure out background-saving it would be the same for manual and auto-saving.
But you are right, one never knows.....
