Issues with the crop region
micah
micah
I recently tried using the crop region command while placing a view on a sheet. The crop region seems to be checked in the properties box but I was unable to do the crop region on the view that i was trying to use on the sheet. I'm attaching a screenshot of the issue. Any inputs on how to fix this will be greatly appreciated.
Micah
You have to activate the View first.
micah
Yes, we did activate view. We tried toggling on and off the Crop View and Crop Region Visible buttons, as well as Scope Boxes. It seems to be a bug. As soon as I posted this issue the Crop Region became visible as it should be, and now again it is not visible. I've seen this before, where the Crop Region Visibility gets hung up going in or out of a Scope Box. Usually I can fix it by messing with the toggles as described above. No such luck right now. Today is the first day with Revit 2017 - are there known bugs such as this with 2017?
artejon
Have you tried to use icons at the bottom of a screen instead of checkboxes in properties ?
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
