Issues with Material mapping
Dear Friends,
If I import any of the CAD model file in Revit Family, It'll not shows the correct mapping (material) on vertical faces.
I am attached here the sample of the issue where you can see that the CAD import model wont come with proper mapping.
Can anyone please help me on this issue.
Thanks in Advance.
cbcarch
Also make sure Imports in Families is checked in VG under Imported Categories.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
You don't have as much control over mapping of texture on imported models as with native Revit models. In this case, you would need to create a rotated material and assign it to the imported layer via object styles.
