Issues with 2017 to Autodesk 360 Rendering
Hi, I recently upgraded my revit model to 2017 from 2016. I was able to render in 360 without any issues in 2016 and now when I try to upload the model to render I get the error in the attached image. Any advice would be helpful thanks. REVIT 2017 ERROR.png
matthew.d
Hi @Anonymous,
Welcome to the community!
Sorry to hear about the issue. These errors might be related to network issues. Check that your network works correctly. If your network is behind a firewall or proxy, please make sure the following are not blocked.
*.autodesk.com
*.cloudfront.net
*.google-analytics.com
*.akamaiedge.net
*.akamaintechnologies.com
*.amazonaws.com
*.edgekey.net
*.googleapis.com
*.msecnd.net
*.microsoft.com
Here is a post describing this in detail.
Try rendering the Revit sample file and see if that works. If this does not help, contact the rendering support team.
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
