Issues importing RVZ files into ArcMap
Message 1 of 14
Good Morning Everyone.  I am having issues with room tags and door swings not appearing in ArcMap using the FME converter for Revit files.  I have attached files my Revit project and what I am able to import into ArcMap for reference.
Replies (13)
Message 2 of 14
Viveka_CD
Hi @Anonymous
I see that you are visiting as a new member.Welcome to the Autodesk Community! Smiley Happy
Which versions of Revit and ArcMap are you using?
Message 3 of 14
Thank you!
I am using Revit 2018 with the latest release of the FME Exporter and ArcMap 10.5.1
Message 4 of 14
Viveka_CD
Message 5 of 14
Revit 2018
Message 6 of 14
The more I play with it the more it seems that I am missing something during the initial export from Revit.  As in the room tags have to be selected/grouped  with the floor plan prior to export.
Message 7 of 14
Viveka_CD
@Anonymous Can you share the file to troubleshoot further?
I can send you a private folder if you'd like.
Also, can you verify that your computer meets the system requirements?
Message 8 of 14
Would you please send me a private folder if you don't mind.  What do you need from my end to make that happen?
My computer definitely meets the system requirements.
Message 9 of 14
Viveka_CD
Hi @Anonymous
I've shared a private folder with you (to the email you've set up in your profile).
Good to know that your systems requirements are fine.
I will need your files to test further and a journal.
Let me know if you have trouble accessing the folder and have any questions.
Message 10 of 14
The file is uploaded
Message 11 of 14
Viveka_CD
Hi @Anonymous
Based on the jpg you attached initially, please upload you ArcMap file and journal as well.
Message 12 of 14
uploaded the gdb files
Message 13 of 14
Viveka_CD
Hi @Anonymous
We are investigating and this issue is in progress.
Meanwhile, can you export the Revit model as an IFC file? Then Convert IFC to an ArcGIS Geodatabase and let us know if there is any difference.
Message 14 of 14
Viveka_CD
Hi @Anonymous
I'm checking back to see if you were able to try the IFC method?
I was able to try the export as an ESRI shapefile, SQLite spatial and FBX. The *.sqlite file works best with all elements intact.
Let me know if you have questions about these processes and export mechanisms.
I look forward to your reply.
