- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to model a new window for a property I'm working on. The existing walls are 550mm thick but the portion of the wall below the Cill is only 300mm thick. I set the cill to the bottom of the reveal and then had the intention of modeling the wall below as part of the window family but this has not worked as intended as it leaves unwanted lines when imported.
Has anyone got any other suggestions on hwo to work around this?
