I am creating a conceptual model of a building on Revit 2017. I have created the outermost geometry of the building and have successfully referenced the mass to reference planes. The reference planes are then dimensioned to the grid lines.
I then try to make cuts into certain parts of the building. My issue is that when I create void geometry and try to align the faces created by the void to the reference planes, only the edge of the face is aligned to the reference plane rather than the entire face. I am unable to select the face because the reference planes will not appear in a 3D view when working with the in-place mass. The model looks ok until I try to flex the mass using the reference planes. The movement of the planes creates canted walls rather than shifting the whole wall.
If anyone has a workaround or solution to this please help. It would be greatly appreciated.
-Dan
Solved by ToanDN. Go to Solution.
I was able to follow the first few steps. However, I am having trouble changing from the solid into a void. I selected the form and under the "Create Form" drop down I selected "Void Form". I get the error message in the picture below. Is this the wrong way to do it? Sorry, I don't have much experience with Revit.
