Issue with grids
3 REPLIES 3
257 Views, 3 Replies
Issue with grids
Hi, Im working on the floor plans in a local file . While composing the view i converted the grids from 3D to 2D and aligned it how i want it within the crop view region. but the moment i synchronise it with the central model the whole grids go haywire. They automatically turn back into 3D and the grid bubbles and alignment would have changed by itself. At times when i synchronise nothing changes but if someone else working on the same central file synchronises the issue repeats. The other person is working on the elevation and has hidden all the girds. the grids have been pinned everywhere . Kindly help with a solution if anyone has faced a similar issue.
3 REPLIES 3
Lakshman01
@Anonymous  Before you change the grid bubble in sheet view, try this click & change the 3D to 2D then you align the grid, it works perfectly. Thanks,
in reply to: Lakshman01
I did change the 3D to 2D then moved the grid as per the view. It still changes back to 3d after synchronising
Check that your colleague is not working in the 'Shared Levels and Grids' workset and that it's not editable for them.  Ideally, they switch this workset off rather than turning off the grids and levels in the view.
Forma Design Contest
