Issue with central model schedule fields from linked models
2 REPLIES 2
James_lB2
235 Views, 2 Replies
Hi all,
I attempted to add simple text instance parameters to door families within multiple linked models so that when I created a door schedule within the central I could use that parameter as a field.
After saving, syncing with central, reloading link all of that multiple times. Even closing down revit and reopening the parameter I just created within the door family doesn't
 appear in the field list within the central model. Below is a pic of the parameter I created. I wasn't sure what other info may be needed. So let me know what else might help
2 REPLIES 2
in reply to: James_lB2
You need to add shared parameters to the families in order to show them in schedules.
James_lB2
in reply to: ToanDN
*FACE PALM*
duhh of course
thanks for taking the time
