Issue with Angled Window in Metric Window Family
danielMZJ26
danielMZJ26
Hi!
I’m trying to place a slanted/angled window in Revit that I’ve modeled in Fusion 360 and exported as a DWG file. I’ve loaded it into a project as a family (Metric Window).
The issue is that the window itself is angled, but the wall opening (the "frame" it needs to fit into) is rectangular. I tried using Create → Void Forms → Void Extrusion to cut the shape, but I haven’t had any luck getting it to work.
Does anyone have suggestions for how to handle this? I’ve attached some images to better illustrate the issue.
Thanks in advance!
danielMZJ26
Solved✔️
Mike.FORM
What did you do to solve this so that other users with the same issue can use this for help.
Not sure why you needed to use a void to cut the wall though when using the opening cut tool in the family constrained to the reference planes making the rectangle would be easier.
danielMZJ26
Yes, smart!
I changed the Elevation view from Exterior to Interior, and that gave me access to select and edit the shape (see attached image). After editing, I was able to save and close the shape – and the window worked as expected.
There’s probably no single correct view to use, but it should be possible to edit the shape one way or another – it’s just a matter of finding the right view.
mari.shimode
Hi @danielMZJ26, thank you for sharing the solution! I unmarked your first reply from an accepted solution and mark the second one instead. Please visit us again whenever you have any other questions!
Mari Shimode
