- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
There is some one that can publish Named position for multiples instances of the same Link in a Revit 2018 project that uses Real GIS Coordinates?
Currently if I load a CAD Link without defined geographic coordinates system (only numeric values), I can assign and edit Named Positions to Links; but as soon as I acquire shared position from a dwg with defined coordinates I cant modify or add named positions.
Erasing the geographic information in AutoCAD resolve the issue, but I don't belive this is a desired workaround; it make mo sense to have a new feature in Revit that isn't worthy.
For example, in a residential/condominium project , I can created named positions before acquire shared positions; but if I want to insert new buildings or new building typologies after acquiring shared positions I can't assign named positions to these new link instances.
Here is the issue:
J. Samuel Santana F.
¿Te resultó útil esta publicación? Dale a Me gusta.
¿Tú pregunta fue respondida correctamente? Haz click en el botón ACEPTAR SOLUCIÓN.
¡Resuelto! Ir a solución.
