Hi all, does anyone know how i can make my mullion NOT cut the glass panels? the mullion profile should be next to the glass, like in the example on the right. But when i make a new profile, even though i keep the corect offset from the glass, it still cuts the panel. How can i avoid this? see picture
Solved by ToanDN. Go to Solution.
you might be able to correct in Project by applying a different offset value to the mullion type.
