Is there any methods to lock the view
to1-2.wd
Observer Observer
to1-2.wd
Observer
Observer
although the eye elevation and target elevation already set
when insert other revit file.
the eye elevation and the target elevation will change
as a result nothing can see in the 3d view
Is there any method to lock the view?
THANKS
You can lock a 3D view using the lock icon on the bottom bar.
What are you talking about?  Your brief synopsis is sorely lacking details.  Elaborate your workflow and results so we can understand.
Liloust
Vous trouverez cet outils dans la barre en bas de votre écran (une petite maison avec un cadenas)
Well, that's 2 for Lock View. I'm still on fence however - primarily because I don't understand your workflow.  What do you mean by "insert other Revit file"?
Bramdejong1985
Observer
Observer
Yes there is a button in the View Options beneath the drawing area to manually lock a 3D view.
Hoever, why not automate this task with a method in a script.
So yes there is a method to lock the views.
In python, it would look something like this:
    # Start transactie (pyRevit style)
    with Transaction(doc, "Oriëntatie vergrendelen") as t:
        t.Start()
        success_count = 0
        for view_name in selected_views:
            view = next((v for v in view_list if v.Name == view_name), None)
            if view and not view.IsLocked:
                view.SaveOrientationAndLock()
                success_count += 1
        t.Commit()
