Is there a way to manage (add, delete, edit) levels in Revit other than adding elevation tags in a section view?
svalen
Message 1 of 13
svalen
Like a level manager or something?
Replies (12)
Message 2 of 13
How do you mean?   Can you post some screenshots with your questions? That would help us to help you.
Message 3 of 13
martijn_pater
No, I suppose you always manage it in section view... Although you might have such a coordination view set up just to coordinate levels for instance... You could have a look at some add-ins maybe, or here , or here i.e.
Message 4 of 13
constantin.stroescu
  • you can do a Schedule for Levels where you can control the Elevation, you can change Names or delete Levels:
by right clicking the Row you can delete the Row and with this the Level....
  • another way of controlling Levels, can be by using Dynamo or an Addin...
Constantin Stroescu
Message 5 of 13
martijn_pater
This schedule solution is quite close to having a 'level manager' actually, nice answer. Worth a try.
Message 6 of 13
RobDraw
I think it is more like a level manager on steroids but, hey, that's just me.
Rob
Message 7 of 13
martijn_pater
@RobDraw Not really, unless it can add levels aswell... but otherwise it's quite close.
Message 8 of 13
s.borello
What about a level schedule?  Would that work for you?
Message 9 of 13
lim.wendy
Hi @svalen,
Thanks for reaching out to the forum. Have you had a chance to look over the suggestions provided by our experts?
Do you have any questions about it, let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you. 🙂
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 10 of 13
svalen
This seem like a good idea....how do you create that?
Message 11 of 13
constantin.stroescu
Create a Schedule/Quanties and you will be able to control the Model.
Every change in Model will reflect in Schedule and vice versa...
Constantin Stroescu
Message 12 of 13
martijn_pater
... perhaps the ultimate 'level manager' within Revit would be combining a level schedule and a level coordination view on a sheet, similar like a (startup) sheet with project information i.e.
Message 13 of 13
constantin.stroescu
good idea...
We'll be able then to   create a View Template of the Level Coordination View (that contains only the main information) and both with the Schedule of Levels to introduce in our custom Template file,,,
Constantin Stroescu
