I have several levels set up in a project, however when I cut a section, these created levels don't necesasrily
show up. For instance, I have a "first floor" level, I cut through the the level, and in section the tag for first floor is not there.
Any reason why?
Tags are View Specific Elements.
Are the Element Tagged still within the View Range?
...I think I'm a little confused. Are we talking Sections or Plan View. Sounds like turning OFF your Crop Boundary and maybe setting your Far Clip to "None" would solve your issue -- if we're talking Sections.
Post a screenshot or two please.
Really depends on where you placed the level. Go to 3d and turn on the levels. Then stretch them over to your building. This should make it show up in your section.
Just be aware that there is 3d/2d level. Most often user make mistake by dragging the 3d. Always click on the 2d and then stretch so it won't effect the 3d extent.
