Is there a way to input the value of the angle directly as you are creating line
chhuanmawia18
chhuanmawia18
 apart from the snapping options , is there a way to input the value of the angle directly as you are creating lines , like that in autocadUntitled.jpg without having to press escape and revising the value .
constantin.stroescu
if you Uncheck Chain , then it could be done, in a way...You'll be able to type the angle value when creating the line.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/screencast/Main/Details/779...
Constantin Stroescu
Jason_S
Constantin,
You are selecting an end point of the line and then changing the angle.  I think the original poster wanted the ability to type the angle in and have it hold that angle as he draws the line, wall or what ever.  I started and Idea on allowing the user to tab to the temporary dimensions in cases like this where picking and end point too soon isn't the easiest option.
See the idea here:  https://forums.autodesk.com/t5/revit-ideas/have-the-ability-to-select-other-temporary-dimensions-dur...
chhuanmawia18
this is the problem that i am facing . Doing this takes too much time while creating multiple lines . I guess there is no option of tabbing to the temporary dimensions
SteveKStafford
Are you sketching at consistent angles relative to the view? You can toggle on the Workplane and rotate the grid to that angle so sketching will allow for sketching at that angle easier as well as snapping to the grid spacing intersections.
Steve Stafford
