Hello everyone!
I'm developing a project in Revit and need to import some jpeg images to use as references, but I need to crop them, in order to place them in my sheets. Does anybody know a way to do it in Revit, or will I need to crop them in an external aplication like Photoshop?
Thank you very much!
Solved by JOHNWHITCRAFT1554. Go to Solution.
Solved by constantin.stroescu. Go to Solution.
You can use :
1. with Mask..
Constantin Stroescu
Not sure if this will be any help at this point, but this is what I do.
1.) Right click on a level and duplicate.
2.) Rename level to the name of the image.
3.) Import image on that level.
4.) Turn on the show crop region.
5.) Crop around the image how you need it.
6.) Open the sheet you would like the image to be located.
7.) Drag the name of the level that represents the image to the location on the sheet.
8.) Then activate the view for the image.
9.) Adjust the size of the image by changing the scale to fit the image.
This will create the image as well at the title for the image. The only issue is that the title has a scale that is associated with the viewport. If you did not want the title then drag the title way off of sheet so that it will not show up on the export/print.
If you don't have enough knowledge about cropping software or tools then you must ask this for clipping path service provider they will tell you exactly the same and help to crop your imported images.
Use the image cropping tool.
Doesn't seem exist in AutoCAD.
But it does in paint.net! (sorry Autodesk)
I quickly pasted the image there -- cropped it -- then replaced it in the AutoCAD drawing.
It does NOT work great. This is a workaround for something which should be much, much easier. Honestly - first paste your image in to a level, then insert a view on to your sheet, then crop your image. Madness. The tools for cropping clearly exist - you can use them for a floor plan. Cut the crap. Should have happened years ago. This is Revit 2021!!!
Seriously! I'm returning to Revit after years of being an ArchiCAD user. I'm floored that this hasn't been solved. Does Autodesk not expect that we're going to be using Revit to layout our cover sheets, to place renderings, maps etc.? Revit needs to perform (at a minimum) as a graphic design layout program, for a number of applications. Despite the aspirations of BIM, at the end of the day, our final output is a series of 2D drawings laid out on sheets (digital or otherwise). This is baked into our laws (at least into the United States).
You guys are way too generous in marking this as a "solution". It's not a solution. We're in revit 2023, and there is still no way to actually crop an image. This is one of a hundred simple basic function that the first release of Revit should have had.
Why is it still not possible in 2023? We can do it in Word (reaaaallly good with images...)
If all you want is to fit an image in the sheet frame. In 2023 version select the Floor plan and check Crop View and Crop Region Visible in Properties panel then adjust the visible frame.
