- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am new to Revit and trying to set up sheets for a project. What I am trying to do is find an easy way to make it so that all plan views are placed on the same spot on each sheet. What I mean is that for example for all the plan sheets (basement, 1st floor, 2nd floor, roof, in this case) I want to have two plans on each sheet (one for existing/demo, one for proposed), and I want it to be neat so that on each sheet, each of the two plans are aligned in the same spot across sheets, if that makes sense? I'm familiar with adobe Indesign, and in Indesign you can use the 'frame' tool to place frames/placeholders that you can then place something (image,text, etc.) into that frame, and that way it's automatically located/sized how you want. Is there some way to do the equivalent in Revit? Ideally I could place a placeholder 'frame' in a sheet template, and then that way when I create a new sheet using that template, I easily know exactly where to place the plans on that sheet. Is this possible?
Sorry if this is convoluted, and thank you very much in advance!
