Is it possible to put lights without hosting it
Message 1 of 24
I have received a project from a consultant and the file does not have ceiling on it. Creating ceiling could be risky because it might have some bulkheads or other stuff on it. I was wondering if I could put the lights without hosting it . If there is any option to specify the mounting height for the lights. ANy idea please?
Replies (23)
Message 2 of 24
You don't need to create ceilings. Use lighting fixture families in Lighting\MEP folder, they are face based families so you can place them directly on any surface of the link model. When placing, look at the Ribbon to pick Vertical, Horizontal, or work plane.
Message 3 of 24
PijPiwo
To add to @ToanDN, in the OOTB library, there is also a studio light.rfa which is only a light source and it’s a level based family. Giving an offset from level, you could place it anywhere.
Message 4 of 24
chrisplyler
Another option is to create a new Level for a floor's lighting fixtures, open a plan view  (or RCP if you prefer, and depending on which way the fixtures are modeled) of that level, and host them right onto the Level. I do it all the time.
Message 5 of 24
RobDraw
Use non-hosted families and assign the elevation.
Rob
Message 6 of 24
The best workflow is to create a ceiling level and host the lighting fixtures on it because if you don't host them on a level you can't change their elevation in one step which may occur at any moment by the architect .
If my answer helped you , please kudo and accept as a solution.
Message 7 of 24
RobDraw
Not as the question was stated.
"I was wondering if I could put the lights without hosting it . If there is any option to specify the mounting height for the lights."
Remember also that there is no best workflow because people work in different ways. For example, I would avoid using levels as a lot of my projects have multiple ceiling heights in different areas. Levels are much harder to control that workplanes, which, IMHO, are a much better option, if you want to use hosted families.
Rob
Message 8 of 24
I know what the question was but it will cost him much time so the hosting level is a good solution for lighting fixture but it isn't a good workflow if you
place air terminals for example.
The workflow i suggest is working very well in my project with almost 13000 lighting fixtures.
If my answer solved your problem , Please Kudo  and Accept as solution.
Message 9 of 24
RobDraw
Just because it works well for you, doesn't mean it is the best for others. There are plenty of places that don't use hosted families for anything.
Rob
Message 10 of 24
It is up to the man with that problem to decide whether to use it or not.
Message 11 of 24
RobDraw
You are a tough nut to crack. Think outside of the box.
Rob
Message 12 of 24
chrisplyler
Any family that DOES have the ability specify an offset (or mounting height) has to - logically - know its offset FROM something.
This usually means its a family that is hosted to a Level. You use a fixture that is hosted to a Level and then you can set the offset for each instance as you desire.
Message 13 of 24
Maybe you are not a good nut cracker,look at the bigger picture and try to extract knowledge and don't bother by unimportant details.
Message 14 of 24
Is it possible to put mounting height as a parameter and not using the vertical, horizontal or work plane option?
Message 15 of 24
Great!! so does it mean that I can host to the floor and then give the mounting height as  the offset?
Message 16 of 24
How do I know which one is non-hosted lighting fixture? Can I create one? Or duplicate the properties and assign the constraints?
Message 17 of 24
RobDraw
I'm fairly certain that all of the lighting fixtures that come with Revit are hosted. You would have to find some from a trusted source or make your own.
Rob
Message 18 of 24
chrisplyler
It means that you can place "On a Work Plane" (that is a Level) and give the mounting height as the offset.
Message 19 of 24
RobDraw
@chrisplyler wrote:
"On a Work Plane"
Key words there because work planes are much more versatile and easier to control than levels.
Rob
Message 20 of 24
chrisplyler
@RobDraw wrote:
@chrisplyler wrote:
"On a Work Plane"
Sure, but the OP is looking for a way to set offset above a floor. In this case, using a Level as the work plane (which is the default condition unless you set a different plane as the workplane first) is perfect.
