Hello
Revit 2017 has been installed on End-User machine and while opening first time from the installation it is initializing and showing as white screen
as below, once clear the user data from C:\user\xxxx\Appdata\local\Autodesk and C:\user\xxxx\appdata\roaming\Autodesk\Revit , its showing the activcation window but it is not moving further.
Product info:
Revit 2017 Network Floating License,
Windows 7 Enterprise Operating System.
Action Taken:
I am awaiting for an expert suggestions here to solve this task as its strange.
Thanks in advance.
D.M.Babu
Gelöst! Gehe zur Lösung
Gelöst von LukeCrowson. Gehe zur Lösung
Gelöst von mslosar. Gehe zur Lösung
Did you clear the user data after reinstalling it or not ?
Try to uninstall using the autodesk uninstaller not the usual uninstall.
Make sure you have an internet connection.
If my answer helped you , please kudo and accept as a solution.
Just ran into the same error.
Fix was/is run Revit as an administrator - right click the shortcut and choose run as administrator. Then you'll get the licensing screen. Do that, and you should be good to go.
Sounds as if you're in a locked down more than usual environment (i know i am
) and you need rights to do the licensing portion of things.
Had the same issue.
Finally resolved it after uninstalling / clearing residual files / reinstalling etc (Non seemed to work)
Just hit "F5" on the Activation page that has not loaded - (Refresh and should load as normal)
You can then select the licence you have - Network / Stand alone etc.
