is it possible to create a curved reference plane?
cadomatic
Message 1 of 15
cadomatic
hi
i want to create a reference plane in the property 4 sides,
there are 2 curved lines, and 2 straight lines.
i could create reference for the straight lines, but count do it for the curved lines.
is there any why to do it?
Replies (14)
Message 2 of 15
Why do you need a curved reference plane?  What are you going to do with it?
Message 3 of 15
Create curved grids and a mass form to see the line when cut in section.
Message 4 of 15
HVAC-Novice
curved plane is an oxymoron:
NOUN
  1. a flat surface on which a straight line joining any two points on it would wholly lie:
    "the horizontal plane"
    ADJECTIVE
    1. completely level or flat:
      "a plane surface"
Revit Version: R2026.4
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Message 5 of 15
hmunsell
does it have to be a "Reference Plane", a Reference Line can be curved, would that work?
Howard Munsell
Message 6 of 15
Shay.Gaghe
i want a reference line or grid line in plan to be indicated by a vertical line in elevations and sections.
i see that elevation view can show that vertical line only if it's parallel to the camera.
What if i need to show 2 lines which none is parallel to the camera?
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
Message 7 of 15
Shay.Gaghe
do not understand
Message 8 of 15
Shay.Gaghe
yes. how to do it?
Message 9 of 15
hmunsell
After seeing your clarification a few messages earlier, I don't think a reference line will work for you either. Reference Lines are used in Families an not available in Project models.
Howard Munsell
Message 10 of 15
Shay.Gaghe
any idea?
Message 11 of 15
hmunsell
Normally id recommend what @ToanDN suggested with a Curved Grid. But as you have seen, it wont show the section line unless the section is perpendicular to the grid.
Since you have a unique circumstance, you may just need to use the Curved Grids in plan and place linework in your Sections and Elevations as needed.
Howard Munsell
Message 12 of 15
I'm still not understanding, but you're in a Modeling Environment, so why can't you use MODEL elements as "RERERENCES"? You can control the references' visibility and graphical display by Element, by Category or by Filter. For example, you could use a Model LINE.
...actually, in your case, sounds like a "Reference" Wall would be better than a Model Line.
Message 13 of 15
HVAC-Novice
A "plane" is defined as flat/straight. You want it curved. At the moment it is curved, it is NOT a "plane" anymore. So what you are asking for is not possible by definition.
Message 14 of 15
nrodriguezYDRXS
So useful.
Message 15 of 15
masroor_javid_mj
I am thinking that if a curved element such as a wall can be created identical to the curve you would like to define as a "plane", then you might be able to use this wall's faces as a plane. Does that make sense? I am not sure if Revit can do it, but for sure human brain can grasp it.
