Is it possible to copy elements from inside one group into an other group?
don_doh
don_doh
I have two groups, where I wish to copy some of the elements from inside the group one and paste those elements into group two, is that possible?
and if it is, how do I do that? (I am using "Revit LT 2017")
I have tried double clicking group one, selecting the elements I wish to copy, pressing Ctrl-c
then exiting group one, double clicking group two, and pressing Ctrl-v while inside group two.
But that did not work, the copied elements did not appear.
(I am rather new to Revit, so I might need a more thorough explanation, than a experienced user).
I think you need to paste it to the outside of group 1 first, then edit group 2 and use Add function to add thst element to group 2.
don_doh
Thank you, your reply helped me to find solution 🙂
When I tried to copy it to outside the group, it said, that none of the created elements are visible in the view...
But I then tried copying the entire Group 1, and then "Edit Type", "Duplicate..." (to not mess with the original Group 1),
and then removed the elements I needed to put into Group 2, and then added them to Group 2, and that worked 🙂
