Is it possible to add a symbol to a spot elevation?
youssef.ibrahimM37J6
Message 1 of 8
Replies (7)
Message 2 of 8
Simon_Weel
You mean the prefix symbol shows up as square? That's probably because the text style doesn't have that character. I.e. use a text font sporting that character.
Message 3 of 8
the same front is used for text and spot elevation
Message 4 of 8
syman2000
I would use different font from Arial to Arial Unicode MS
Message 5 of 8
Re: Is it possible to add a symbol to a spot elevation?
What kind of symbol? Like a plus-minus symbol or a musical note symbol? 😉
Paste one from your Window's Character Map into the prefix or suffix field under the instance properties of the Spot Anno.
Open and Use Character Map in Windows | Tutorials (tenforums.com)
Message 6 of 8
is was the
Message 7 of 8
@syman2000  Than you, approached it
Message 8 of 8
@youssef.ibrahimM37J6 wrote:
is was the
