is it possible insert image in revit family(.rfa)?
diego_fernandez_91
Message 1 of 8
diego_fernandez_91
Hello
Does someone know if it is possible to insert a small size picture into a revit family? I am not asking into a in a revit project
When I try to insert as an image I keep getting the message: "the imported family will not be visible in the project. To improve performance delete the image before saving the family."
I have tried with a smaller size picture
Replies (7)
Message 2 of 8
ennujozlagam
you can refer to this previous thread and see if helps. thanks
Message 3 of 8
Hi , this is a good question and thanks to share it, i try to see if we can import image in rfa and it is passible as i saw but revit asks you to delete the image when you finish and want to save the file for beter performance and here a video for my experiment
Message 4 of 8
hmunsell
you could use the image to create a material. then assign the material to the object.
  • Manage ribbon > Settings panel > Materials
  • duplicate a Default material
  • in the Appearance panel, you can load an image.
you may need to mess with the image scale and positioning and set the Repeat to None if you only want it once.
Howard Munsell
Message 5 of 8
What kind of family?
Message 6 of 8
syman2000
You can insert the image into generic annotation and use that as a family. Image will not work with detail or model family.
Message 7 of 8
Dizayn03
Observer
Observer
it is still comes as image and comes with seperate files whe you export it to cad.
Message 8 of 8
hmunsell
When exporting to CAD, Images inserted into a family, or Model, will export as separate files. only way around that would be to use a Material. I believe Autodesk material libraries are shared across there software's. So when exporting to CAD, the material should still be accessible.
Howard Munsell
