Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
irregular concrete staircase in Revit
rahulkarna
rahulkarna
 I want to draw a stair case like the attached one. Can anyone let me know how can I?
Create it in Stair by Sketch and draw the boundary lines and riser lines.
Green are boundary lines, black is riser lines. Break the boundary lines at landing as shown.
Kimtaurus
When you use "Stair By Sketch" you actually lose some functunality for your stairs (tread number, stair path).
I'd suggest using "Stair By component" and then use "By Sketch.It works the same as Stair By Sketch, but you can add a stair run.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
