Invisible lines Style
I can't explain it, but there are no <invisible line> in the projects of the firm that I recently joined.  No one knows why.  I want to add them back into our projects.  I have searched through our templates and some old files but haven't found any with the system <invisible line>.  How can I add that back into our projects?
Nardo
Invisible lines are in families...there isn't one in the project environment unless someone created their own that is white or an insane line pattern.
<invisible lines> is only available when you create a boundary of certain objects such as a filled/masking region, or an in-place model. If you want want to draw some lines and make it invisible then create a new line style and change it to white, very thin, and maybe of a dotted pattern. Don't over use them because they can mask other element in the drawings.
oops...forgot about fill patterns...
