Invisible electrical devises
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am using version 2020 with phases: existing and new.
On the existing floor plan, I have a simple residential unit with the being the same basic 6" wall. I have applied outlets to 2 of the walls that can be seen. On the north wall, I tried to place another of the same outlet and poof...nothing. Some of walls will accept a outlet and others will either not or the outlet isn't visible. Below is what Revit throws back at me:
"None of the created elements are visible in Floor Plan: EXIST FIRST FLOOR WITH UNIT 2 Copy 1 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings"
I have not a clue what the above means. There is an PDF attachment.
