Invisible electrical devises
rmaynard
rmaynard
I am using version 2020 with phases: existing and new.
On the existing floor plan, I have a simple residential unit with the being the same basic 6" wall.  I have applied outlets to 2 of the walls that can be seen.  On the north wall, I tried to place another of the same outlet and poof...nothing.  Some of walls will accept a outlet and others will either not or the outlet isn't visible.  Below is what Revit throws back at me:
"None of the created elements are visible in Floor Plan: EXIST FIRST FLOOR WITH UNIT 2 Copy 1 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings"
I have not a clue what the above means.  There is an PDF attachment.
Keep this list handy. It's exactly what you need in situations like this.
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
rmaynard
I haven't tried XRAY as of yet.  I seems a bit expensive.  I'm glad there is a trial period.
I think you missed the point. I wasn't referring to XRAY. I was referring to the list of 33 things to check.
Here's the original list:
Can't see it in the view? Here's 33 reasons maybe why - Revit Forum
