I want to calculate the number of multi-circuit wires needed to carry a number of circuits. I have attached a snip of the problem that occurs. I've declared the (shared) parameters as Number and Instance, simplified by omitting Roundup, which has to be there for the result to be real-world, thinking that was the issue (I'm not sure if Integers can co-exist with numbers, even using Roundup), and copy and pasted the text to avoid spelling mistakes, but it still doesn't work.
Check the attached snap file
Hello @Anonymous
This seems to address your issue.
Issue |
Cause |
Solution |
See Also |
Let me know how it goes.
Best regards.
Hi all;
I also posted this problem on an independent Revit forum. A member there came up with what turned out to be the solution.
I had to check the formula in each type to ensure no type might wind up dividing by zero, so all occurences of the divisor had to be explicitly non-zero, which involved flipping throught the types to change and confirm. A non-value was not acceptable. I set them all to one. Then, the formula worked fine.
Thanks for working on my problem.
Dave
