We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Intersection when pointing/moving
Tilda.BlomqvistUGS2Q
Message 1 of 19
Hi!
I'm trying to move the plan I'm working on to align with the grid guide. The moving part or grid/guide is not the issue for this thread (I think), and watching a tutorial (cred to TPM Solutions on Youtube), it show their pointer marks out what the Intersection is between two lines in the plan.
What can I do to make it does on my computer? Because it dosen't and I don't know how to fix it.
Many thanks
Replies (18)
Message 2 of 19
Uncheck Disjoin
Message 3 of 19
Thanks!!!
For clarification, ticked or unticked?
Also I wonder, how much should the plan should be selected? Only once or twice?
Message 4 of 19
Unticked.  That will be the default condition until you change it.
Message 5 of 19
Okay thanks.
Seems to be some other issue though as its been unticked
Thanks though
Message 6 of 19
Are you saying that you cannot align the x,y Grid Intersection in the View to the Grid Guide on the Sheet using the Move tool?
Message 7 of 19
Sorry - the image is a screenshot from a youtube video and is not mine. All I'm wondering is how to get that white box "Intersection" to appear when hovering above an intersection such as when two lines in a plan meet.
Here a link to the video btw: https://www.youtube.com/watch?v=lfBC6lQUUHQ
Message 8 of 19
You need two intersecting grid lines or reference planes in the view, in order to snap their intersection to the sheet's guide grid.
Message 9 of 19
Press the Move tool and then hover mouse cursor over the x,y Grids interesction.
Message 10 of 19
Yes, I'm doing that, but no 'Inteserction' message comes up
Message 11 of 19
Right-Click and press Deactivate View.
....just to be clear, you are on a Sheet with Grid Guide Activated and you have placed a View containing Grids on that Sheet.  Is this correct?
Message 12 of 19
Thanks.
I found thought that the view was already Deactivated.
Not sure if I should have had the mouse on/over something specific when doing so though
Edit: Yes, that is correct.
Message 13 of 19
And yes, that is correct
Message 14 of 19
Turn On Snaps from the ribbon menu.
Message 15 of 19
Message 16 of 19
That totally makes sense I looks like the solution but I tried on my computer, however, unsuccessful, which was surprising.
I've noticed the other messages such as "Nearest" comes up when I hover over a drawing. However, that was in another file, not sure if something's possibly wrong with the one I'm working in
Thanks anyway
Addition: this is what is looks like when I right-click on the move button (regardless if I have the object to move
Message 17 of 19
You need to press Move and then hover your mouse cursor over the sheet near the intersection you want to snap to - and then right-click to select the Snap Override.
Message 18 of 19
Check Snaps.
Message 19 of 19
lim.wendy
Hi T,
Welcome to the Revit Architecture forum. Thank you for submitting your question in our discussion forums.
It looks like Toan's suggestion to disable all snaps works, so for now, I will mark this thread as "Solved." This won't prevent other folks from commenting on this question though, in the event other ideas come up!
Please let us know if you require further assistance.
Remember to mark your posts as having an "Accepted Solution" if a solution is found as it helps other forum users with the same issue – so don't be shy about marking it as a solution! Accepted solutions get viewed more and help more users find the answer to their problems. . You could unmark the post as an accepted solution if the solution did not work. Click the ellipsis menu  > Not the Solution to cancel an accepted answer.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
