Interior Window Trim
carol.bandy
carol.bandy
Greetings,
I am trying to incorporate a manufacturer-provided interior trim file (Classic Craftsman) into my Revit model. I am able to get the crown molding sweep into the model just fine. I can not figure out how to adjust the other molding profiles - i.e. the head trim,etc. to fit various windows and doors. Here is a link to the Revit files on the website. Thank you, in advance for your assistance.
https://windsorone.com/resources/cad-files/revit-files/
CB
mphungDCHNW
Have you tried void extrusions yet?
carol.bandy
No I have not. I was trying to use the trim - revit files - provided on the link above - just adjust them. Thanks!
MichaelWarwick7522
Edit the family and add a length parameter.
The sweep has a tiny return to make the end mitre, so add another pair of reference planes offset by 3/4, dimension and lock the dimension, then edit the sweep, edit the path, align and lock the return to those new reference planes.
Hope this helps.
carol.bandy
Awesome, thank you.  I will give it a try in the am and let you know how it goes.
@carol.bandy wrote:
Greetings,
Sweeps are made with 2D Profiles.  Edit the existing Sweep and change the Profile it uses to the Profile you want to use.
...here's a parametric trim in a door family:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-M...
carol.bandy
Thank you for your input. I will give it a try.
